Tray Support Rings as External Pressure Stiffening Rings
Does anyone have any opinions/tips regarding rerating an existing tower for F.V. by using Tray Supports as external pressure stiffening rings?
I am aware that the Tray Supports are subject to UG-29(a) and UG-29(c) in order to comply with code standards.
There is a previous thread with the same question:
http://www.eng-tips.com/viewthread.cfm?qid=13381
Eddy
Eddy
RE: Tray Support Rings as External Pressure Stiffening Rings
Thus the tip is; tell 'em it is impossible without an Internal Inspx with the tower squeaky clean. No slimy lower sections allowed.
