[MSC Patran 2012.2 64 bit] Utilities menu not showing
Hello everyone,
here at work I am using a workstation running Win7 on wich I installed the 64bit version of MSC Patran v2012.2. The problem is I can't see the "Utilities" menu; I tried the workaround suggesting to put the p3epilog file into the working directory or into the main Patran one, without results.
Now I'm asking if someone knows a way to make that menu appear, eventually with a step-by-step description in order to avoid mistakes that I eventually have done.
Thanks to everyone,
David
