Does anyone know the valve(?) in the red circle and its function? THX
RE: Does anyone know the valve(?) in the red circle and its function? THX
now the attachment can be downloaded normally.
Can you expand the view? Is that a stream or a handle coming down from the valve?
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
Difficult to tell from the snippet and maybe there is a valve handle missing, but it looks like a manual choke valve to me. the SP/062 tag should tell you??
This looks like a small bore bypass of an ESD valve intended to pressurise or de-pressurise after an ESD trip, hence the control valve, and in the event the bypass over pressures again the actuated 2" valve will close again to protect the D/S system
As drawn I suspect the manual handle has simply either become one of the lines or is missing.
You really should have a key drawing available which tells you or you can get the info from the tag number.
SP :sampling point (?)- 3 ways valve.
Good luck
Pierreick
SP / 062 is a manual choke valve shown upside down - this arrangement is for startup operations to pressure unpack the upstream section as suggested earlier.
It seems to be a three-way valve from the attachment.
Please attach the whole P&ID for more clarity.
Dinesh S SHELATKAR.
Process Engineer
not 3-way, George is right.
pleas attach the whole P&ID for more clarity. it may be drain valve
but (( i know this is strange )in the LEGENDS this symbol refer to safety valve :/ :)
