Quality of Atomization depends on......
This question is specifically focus on siphon air atomizing nozzle, which creates atomization with compressed air. When compressed air enters the nozzle, it creates suction and draws liquid for atomizing process.
Since compressed air is the only driving force for siphoning the fuel and the atomization, it needs to be sized properly. The nozzle we currently use works the best with 15 PSI with 18.4 LPM of air compressor.
In general, for the quality of atomization (size of the atomizing droplets), does it depend on the pressure of compressed air or the volume flow rate of compressed air?
RE: Quality of Atomization depends on......
and flow rate.
By that observation, if the air compressor is switched to a different one which has the same pressure rating but much lower volume flow rate. What would exchange in atomization quality?
Changing nozzle size can solve the problem. Siphon nozzle like this actually is actually selected by the fuel GPM. However, sizing the proper compressor for the nozzle is a different thing.
Atomization takes energy. Smaller droplets and greater liquid flow rate require more horsepower. Your air nozzle and liquid nozzle need to be match for the flow rates.
thank you for the explanation on the relationship between pressure, flow rate and atomization. You were right on the power consumption and the liquid flow rate and droplets.
When I start to spec out the compressors with same voltage and same pressure output, it gives you different flow rate based on the amperage. With this in mind, I can spec out the right compressor. Thanks again
