delete entities inside a boundry (rectangle or square) in journal
Hi -
Does anyone know if it should be possible to find notes inside a "rectangle" defined by two set of coordinates from a journal.
Let's say on a drawingsheet notes that resides "inside" the coordinates X200,Y200 and X300,Y400 can by collected into an array.
My task is to do automate deleting of only some notes one sheet - the area where they residens are known.
lklo
lklo
RE: delete entities inside a boundry (rectangle or square) in journal
Here's the relevant snippet:
CODE
For Each tempNote As Annotations.Note In workPart.Notes 'test to see if the note is in the title block "drawing title" box If tempNote.AnnotationOrigin.X < titleLowLeft.X Then Continue For End If If tempNote.AnnotationOrigin.Y < titleLowLeft.Y Then Continue For End If If tempNote.AnnotationOrigin.X > titleUpRight.X Then Continue For End If If tempNote.AnnotationOrigin.Y > titleUpRight.Y Then Continue For End If 'if we get here, the note is in the box 'code to process note Nextwww.nxjournaling.com
It is an ingenious way to "define" the Square. Simpel and cleane solution.
Thank you very much.
( I have written an NXOpen API which fully automaticly replace our Tilteblocks in all sheets in our dwg parts. )
(But we also have some old dwg part's which contains patterns - I have choosen to divide theese task's in two programs.
And after the sequence where I delete the patterns - there are some notes left that needed to be deleted.
I can do this with the snippet you provided me. The coordinates can be predefined after I have asked for the sheet size )
so everything is Ok.
lklo
