How can I use "Overlay" (command from Inventor) in View?
Hi everyone!
I've been working at assembly component with cylinders and it's necessary to show this ones on drawing.
When I was working on Inventor, it's just to use Overlay command, but now I'm using NX8 and I couldn't find this way.
So, someone can give me a help? I want show One view with overlay of cylinders.
Thanks in advance.
Mauro
Designer
RE: How can I use "Overlay" (command from Inventor) in View?
That sounds something like using 'Layers' and 'Visible in View'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
You might need to throw in 'Render Sets' as well.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Enter overlay in your command finder and see if those two things apply to what you need here
Hello mleitefilho89! What you need is pretty possible to do, that's for sure.
What version of NX are you running?
www.cadroad.com
You can control visibility of items in drafting view using Format>>Layer Visible in View
Otherwise use Reference sets.
If it is a component in assembly, then try using Hide/Show Components in View
Hi PrintScaffold, sorry to not answer you before,
I'm using NX8.
But this video will help me for sure, thank you very much!
Mauro
