[Abaqus] Problem with msg error?
Hi all,
I am running the simulation about a tire lying on a road and adding load on the sidewall of the tire.
I was given a tire model which the tread of the tire was in contact with the road. Then I made some changes in the 3D input file to make the sidewall of the tire lying on the road. However, when I ran the analysis, the 3D msg file came up with erros as shown below:
MAX. PENETRATION ERROR 28.4217E-15 AT NODE 34677 OF CONTACT PAIR
(SIDEWALL-UP,SROAD)
MAX. CONTACT FORCE ERROR -3.58178 AT NODE 58678 OF CONTACT PAIR
(SIDEWALL-UP,SROAD)
THE ESTIMATED CONTACT FORCE ERROR IS OUTSIDE OF CONVERGENCE TOLERANCES.
MAX. PENETRATION ERROR 235.391E-03 AT NODE 67678 OF CONTACT PAIR
(SIDEWALL-UP,SROAD)
MAX. CONTACT FORCE ERROR 913.912 AT NODE 67678 OF CONTACT PAIR
(SIDEWALL-UP,SROAD)
PENETRATION ERROR TOO LARGE COMPARED TO DISPLACEMENT INCREMENT.
Could anyone please tell me how to solve this problem? Since I am new for abaqus, I may describe the situation not clear enough.
If anyone need more information, please tell me.
Thank you very mcuh.
Jaycee
(SIDEWALL-UP,SROAD)
(SIDEWALL-UP,SROAD)
(SIDEWALL-UP,SROAD)
(SIDEWALL-UP,SROAD)
Jaycee
RE: [Abaqus] Problem with msg error?
Are you sure the meshes are not overlapping each other at any point?
Sometimes contact stabilization helps to solve such issues.
