ASME SEC VIII DIV 1 Vessel , Killed Steel
Dear All,
Pressure Vessel as per ASME SEC VIII,Vessel Size is Dia 2m and length (Tan to Tan )4m Shell Material is A 516 gr 70, So wheather carbon steel plates shall be fully killed??? is there any code requirement for that?
Thanks in Advance smile
RE: ASME SEC VIII DIV 1 Vessel , Killed Steel
SA-561 is fully killed.
Thanks Weldstan smile
am asking about SA-516 gr 70, Hope 561 is typo error, However this fully killed is code requirement?? if you specify the clause then it will be more useful for me ??
SA 516 is fully killed.
561 was a typo.
Weldstan, Can you tell me which clause says this requirement?
4.1 "The steel shall be killed..." Then review Si content (minimum) in Table 1.
Dear Weldstan,
Which code is this ??
Thank You Weldstan smile
SA-516.
