Pressure Vessel Design Training
Dear All
If you have details of free online training for pressure vessel and heat exchanger design please inform me.
Thanks in advance
Thanks in advance
RE: Pressure Vessel Design Training
also see www.cerebroinc.com, they also have some demos available on line. Those are not training program, but works nice and are free. Good lucky.
If you happen to find some worthwhile free training on heat exchanger design, please post. I'd sure be interested - my company keeps cutting its training budget and thinks we don't need technical training while foisting "touchy-feely" stuff down our throats.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of Eng-Tips Forums"
Houston, Texas AREA the best is South Texas Section ASME:
http://www.asmesouthtexas.org/seminars.php
Pressure Vessels: ASME SECTION VIII, DIV 1, DIV 2, DIV 3.
Piping: B31.1, B31.3, B31.4, B31.8
REFERENCE NOTE'S: PAST SEMINAR NOTEBOOKS AVAILABLE
Available at $75.00 per set are:
1994 ASME B31.3 Piping Code Seminar
2001 Piping Design & Pipe Stress Analysis Seminar
2001 Pressure Vessel Seminar - Sec. VIII - Div. 1, 2, 3
Order your seminar notebook from KATHY SMITH at 713-523-4565 or FAX 713-523-6767
and send your check along with your request for the set(s) that you need to
South Texas Section ASME at P.O. Box 25045, Houston, Texas 77265.
REGARDS Upcoming training dates:
January 21, 2003 - COMPRESS
January 22/23/24, 2003 - FEPipe
TO FE-PIPE traning :http://www.codeware.com/docs/TrainingFEPipe.pdf
New All Pro is now available. It includes two very powerful and easy to use programs for analyzing appurtenances on shells (e.g., nozzles, lugs) and flanges by FEA.
REGARDS TO BOS FLUIDS traning:
http://www.paulin.com/
REGARDS TO HEAT EXCHANGER traning:
http://www.codeware.com/hx.html
COMPRESS Build 6198 includes the A02 Addenda of the 2001 Code Edition, optional TEMA and ASME Exchanger modules, new Vessel Wizard, and new Flange Wizard. Read more about it here
Regards to HEAT EXCHANGER TRAINING:
• Heat Transfer Research, Inc. (HTRI): To advance heat transfer and fluid flow technology for our customers by conducting research, developing practical methods and computational tools, and providing related services.
http://www.htri-net.com/
New Letter http://www.htri-net.com/PDF/Exch41.pdf
Leonard@thill.biz
www.thill.biz
Prode: Software for pure and mixture fluid properties, heat exchanger thermal design, and chemical process simulation.
http://www.prode.com/home.htm
Leonard@thill.biz
www.thill.biz
