Stock size in NX 8.5
How to represent stock size of machining component in NX8.5??
RE: Stock size in NX 8.5
Represent stock size ?
- Document the stock size ?
Tomas
iam looking like representing 3D block which shows the stock size that need to make the part
DO U WANT TO REPRENT IN DRAWING OR DO YOU WANT CREATE ANY BLOCK.
If you want bounding block creation there was journal which will create rectangular bounding box
Exactly what I was looking gani, long back in my previous company I seen that bounding block creating on the part. Do u have that journal??
If stock size to be shown in drafting how do you show it??
here is the code from GTAC which will create bounding block with respect to the relative WCS
CODE -->
' Will be prompted to select a body and will make a bounding block
' based on the WCS
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
Imports NXOpen.Utilities
Imports NXOpen.UF
Module make_bounding_block_of_selected_body_relative_to_wcs
    Dim s As Session = Session.GetSession()
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = s.ListingWindow()
    Sub Main()
        Dim a_body As NXOpen.Tag = NXOpen.Tag.Null
        Dim csys As NXOpen.Tag = NXOpen.Tag.Null
        Dim target As NXOpen.Tag = NXOpen.Tag.Null
        Dim blockFeature As NXOpen.Tag = NXOpen.Tag.Null
        Dim min_corner(2) As Double
        Dim directions(2, 2) As Double
        Dim distances(2) As Double
        Dim edge_len(2) As String
        While select_a_body(a_body) = Selection.Response.Ok
            ufs.Csys.AskWcs(csys)
            ufs.Modl.AskBoundingBoxExact(a_body, csys, min_corner, directions, _
                distances)
            lw.Open()
            lw.WriteLine("Min_corner: " & _
                min_corner(0).ToString & ", " & _
                min_corner(1).ToString & ", " & _
                min_corner(2).ToString & ", ")
            lw.WriteLine("X direction: " & _
                directions(0, 0).ToString & ", " & _
                directions(0, 1).ToString & ", " & _
                directions(0, 2).ToString & ", ")
            lw.WriteLine("X distance: " & _
                distances(0).ToString)
            lw.WriteLine("Y direction: " & _
                directions(1, 0).ToString & ", " & _
                directions(1, 1).ToString & ", " & _
                directions(1, 2).ToString & ", ")
            lw.WriteLine("Y distance: " & _
                distances(1).ToString)
            lw.WriteLine("Z direction: " & _
                directions(2, 0).ToString & ", " & _
                directions(2, 1).ToString & ", " & _
                directions(2, 2).ToString & ", ")
            lw.WriteLine("Z distance: " & _
                distances(2).ToString)
            edge_len(0) = distances(0).ToString()
            edge_len(1) = distances(1).ToString()
            edge_len(2) = distances(2).ToString()
            ' Create a block
            Dim workPart As Part = s.Parts.Work
            ' Create block feature builder
            Dim nullFeatures_Feature As Features.Feature = Nothing
            Dim blockFeatureBuilder1 As Features.BlockFeatureBuilder
            blockFeatureBuilder1 = workPart.Features.CreateBlockFeatureBuilder(nullFeatures_Feature)
            ' Define block by Origin and edge length
            blockFeatureBuilder1.Type = Features.BlockFeatureBuilder.Types.OriginAndEdgeLengths
            Dim originPoint1 As Point3d = New Point3d(min_corner(0), min_corner(1), min_corner(2))
            blockFeatureBuilder1.SetOriginAndLengths(originPoint1, distances(0), distances(1), distances(2))
            ' Create the block by committing the builder
            Dim feature1 As Features.Feature
            feature1 = blockFeatureBuilder1.CommitFeature()
            ' The function below is accessing an old UFunc to create the block. The UFunc however requires
            ' a solid modeling license - which does not work in cam_express. The above method to create a
            ' a block uses the new JA methods. And that will work with a cam_base license as well.
            'ufs.Modl.CreateBlock(FeatureSigns.Nullsign, _
            '                     target, min_corner, edge_len, blockFeature)
        End While
    End Sub
    Function select_a_body(ByRef a_body As NXOpen.Tag) As Selection.Response
        Dim message As String = "Select a body"
        Dim title As String = "Select a body"
        Dim scope As Integer = UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY
        Dim response As Integer
        Dim view As NXOpen.Tag
        Dim cursor(2) As Double
        Dim ip As UFUi.SelInitFnT = AddressOf body_init_proc
        ufs.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        Try
            ufs.Ui.SelectWithSingleDialog(message, title, scope, ip, _
                         Nothing, response, a_body, cursor, view)
        Finally
            ufs.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        End Try
        If response <> UFConstants.UF_UI_OBJECT_SELECTED And _
           response <> UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then
            Return Selection.Response.Cancel
        Else
            ufs.Disp.SetHighlight(a_body, 0)
            Return Selection.Response.Ok
        End If
    End Function
    Function body_init_proc(ByVal select_ As IntPtr, _
                           ByVal userdata As IntPtr) As Integer
        Dim num_triples As Integer = 1
        Dim mask_triples(0) As UFUi.Mask
        mask_triples(0).object_type = UFConstants.UF_solid_type
        mask_triples(0).object_subtype = UFConstants.UF_solid_body_subtype
        mask_triples(0).solid_type = UFConstants.UF_UI_SEL_FEATURE_BODY
        ufs.Ui.SetSelMask(select_, _
                           UFUi.SelMaskAction.SelMaskClearAndEnableSpecific, _
                           num_triples, mask_triples)
        Return UFConstants.UF_UI_SEL_SUCCESS
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
    End Function
End Module
If you want to show in drawing need to make attributes of block size and call in drawing
How do I build/write this into nx so I can use code because this would be very useful for me?
Thank you.
Regards Daniel.
Copy this code to journal file with extension .vb and Execute through Tools->Journal->Play
this is great
Thank you
Regards Daniel Lamb.
