1/8 BARB DESIGN PA66 25% GLASS FILL. WHAT NOTES FOR TESTING
designed a 1/8 barb made of pa66 25% glass fill. I want to put some notes like pull test force notes and break force notes on the drawing. I put on a 25KG tubing pull test but I want to also put on a note to test breaking force for the barb itself since its only a 1/8 barb, what force should I spec on this? It will not be subjected to alot of force as it the other end is being inserted into a block of plastic. It would be lighter force from user manipulation of the barb and tubing.
RE: 1/8 BARB DESIGN PA66 25% GLASS FILL. WHAT NOTES FOR TESTING
