Need help with an "Error Recovery message
I am getting an message dialog box that is saying Error recovery completed for the following error: Internal Error. I get this when I go to the layer dialog box and switch all layers off and then turn them back on. the error shows up when hitting ok to close out of this dialog box. It seems to correct everything but not sure what is causing this issue.
I have done a part clean up and saved it after the fact but still get the error. File has also been reloaded and same issue.
The reason for using the layer dialog box is that we will be loading more parts into this file for clearance issues checks and we were getting the layers set up for this action.
any help would be great.
Kevin
Kevin
RE: Need help with an "Error Recovery message
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Dialog memory
Customer defaults
Environment variables
But whatever you do, if you feel that you need to contact GTAC, syslogs will be absolutely necessary.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
