Separator Liquid Loading
I need help on calculating liquid loading for a horizontal passive filter separator using natural gas as the product medium. natural Gas SG 0.58. Is there any empirical formula that governs such calculation . Any industry standard that help calculate these parameter?
RE: Separator Liquid Loading
Dejan IVANOVIC
Process Engineer, MSChE
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
One common thing for all filter separators is that they require removal of bulk liquid upstream of the filter elements. I had an opportunity to witness how malfunctioning of a dramatically undersized vertical wiremesh separator upstream virtually cancels out performance of the downstream filter separator. Slugs of liquid water were literally passing through the filter elements.
Dejan IVANOVIC
