Export only current sheet to .pdf
I found this journal here on eng-tips. Is there a version that only exports current sheet instead of every sheet?
http://files.engineering.com/getfile.aspx?folder=0...
RE: Export only current sheet to .pdf
CODE
Also, you may be interested in the code found here:
http://nxjournaling.com/content/pdf-exporter-class
www.nxjournaling.com
