7SJ80 restore settings
I have a problem with the existing settings in one Siemens relay 7SJ80. It is always tripped and it is not possible to change the settings. So, I want to ask you if there is some option to restore the device setting to default with keyboard combination. I know such method for MiCOM devices, so I think that it is possible.
Thank you in advance,
Ivo
Ivo
RE: 7SJ80 restore settings
I have the same problem with 7SJ80. It is always tripped. Is there some trick to reset the factory settings?
Which one is in your case?
