Determining Upshifting and Downshifting lines for AMT
I am modeling a vehicle transmission. I have the transmission ratios, Torque vs RPM, sfc vs RPM curves. I would like to know how the up- and down- shifting lines are determined. It would be nice if I could get some help with it.
Thank you.
Thank you.
RE: Determining Upshifting and Downshifting lines for AMT
If you have a traditional torque converter with a lockup clutch then you need to consider the torque multiplier characteristics, and the torque capacity of the LUC.
then it gets hard
Cheers
Greg Locock
Sorry, the little I know is from proprietary material.
Cheers
Greg Locock
Thank you and please bear with me if the question seems stupid.
Cheers
Greg Locock
In the chart that you linked, the engine RPM follows the lines to the right side of the graph. Imagine the driver starting off from a stop and having a fixed upshift RPM of 2100 as per the graph. The revs follow the 1st-gear line to the right as the road speed increases until the upshift RPM is reached, at which point the revs drop (to the left) while road speed remains the same until it finds the 2nd-gear RPM at that road speed (just over 1500 rpm), and so forth, until the maximum speed.
If the driver slows down (braking), it slows to a minimum speed in each gear (evidently around 800 rpm), at which point the revs have to rise to match whatever it will be in the next gear lower (about 1100 rpm), and so on down the graph.
Is that the understanding that you were looking for?
Or do you get that, but you are looking for the *actual* logic needed to establish the upshift and downshift conditions?
*That*, is exceptionally difficult. The upshift RPM will generally depend on throttle position, and if the driver is cruising at low revs in a given gear but then asks for acceleration, when engine load reaches full torque and the driver is still asking for more, it will have to do a downshift (if it is permissible to do so).
Simple logic like that is how old-school hydraulically controlled automatics worked, and even how older-generation electronically-controlled automatics worked. But it leads to an annoying hunting between upshifts and downshifts when going up hills. A lot of newer automatics infer the amount of slope that you are driving on, and establish a minimum gear that it will not upshift beyond, in order to combat hunting. A lot of newer powertrains are "torque-request" based; they infer how much torque the driver is requesting to be put to the wheels, and pick the right gear and throttle position to achieve that without hunting.
A lot of newer automatics will automatically downshift when going down hills, to make use of engine braking, so that the vehicle doesn't tend to run away from the driver (and it reduces the chance of overheating the brakes).
On an auto tranny with lots of ratios (the new 8- and 9-speed automatics, for example), if you always pick the absolute optimum gear at all times, you will drive the drivers nuts with all the shifting. Every tiny uphill and downhill will call for multiple shifts. So there has to be a "stay in the current gear if it is reasonably possible to do so" factor also ...
Nowadays, the drive-by-wire takes care of it ...
