Teamcenter Baseline to single part body
I am looking to start designing parts within Teamcenter (Version: 8). However a requirement is to export baseline versions to customers with the parameters removed (dumb solid). Is there a way or setting within Teamcenter that when a baseline is created, the supported model is converted into a dumb solid? Keeping the primary file fully parametric for changes at a later time?
Thank you.
CAD Detail and Designer II
NX 7.5, 8, and 8.5 with SmarTeam Integration.
CATIA V5 R20-R22
RE: Teamcenter Baseline to single part body
You can export to parasolid outside TeamCenter very easily in the same way than in native mode
Didier Psaltopoulos
http://www.psi-cad.com
MI95SHO,
JT file generation also supports the option for creating Native JT files from TC managed NX parts.
CODE --> TC_CMD_SHELL
"%UGII_BASE_DIR%\pvtrans\ugtopv.exe" "@DB/item_ID/Item_revision" -pim=yes -u=tcuser -p=tcpasswd -rev=tc_rev_rule_name -save_outside_teamcenter -force_output_dir=c:\explicit_output_location\directory_path
This would provide the ability to access the data in JT2go, TCvis, XpresReview, and in native NX.
It would provide access to the parasolid B-Rep model, the option to include PMI data if desired without exposing KF data, expression formulas, NX feature information etc.
HTH,
Joe
To clarify, I still require the use of -> Export -> To Briefcase, as this is a requirement for sending data. Joe, would your method allow me to baseline a file into a JT file?
Design Technician
CATIA V5 R20-R22
