Portable Document Format
Good morning,
I read the posts here and learn much. Thank You.
Is there anyway possible to bring a pdf file with hyperlinks into excel
Thanks in advance.
R/
Matt
Thanks in advance.
R/
Matt
RE: Portable Document Format
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Thanks. I'll get into it.
These spreadsheets are used by our Engineering staff to reference quickly the related code sections to a specific requirement. I am compiling the references into one hyperlink per subject. It will be included as a tab to the existing sheets used.
Thank you again,
R/
Matt
The process in excel 2013 is
Click Insert, Text, Object
Create from File, browse to PDF file
Check box "display as icon"
Click change icon to change the text that appears under the icon to just the file name.
Then when someone double clicks on the pdf icon, the pdf will open in acrobat reader.
Thanks.
I had "saved as" like was mentioned above and all it did was bring in the text. Seems to just be a one button click to replace cop and past in the cells.
I think the is the simple solution we needed.
Thanks again to this forum.
R/
Matt
