NX 10 Block UI Styler: Property Expanded of a group
Hello everyone!
I have created a dialog using the Block UI Styler. The dialog contains a group with a couple of elements inside. I want this group to be minimized, when the dialog is started. Therefore, I set the property called Expanded to be False. But instead of becoming minimized the group simply disappears from the dialog. Is there a solution for this? Thank you very much!
Best Regards
Best Regards
RE: NX 10 Block UI Styler: Property Expanded of a group
Mark Rief
NX CAM Customer Success
Siemens PLM Software
