How to remove slope analysis in nx9?
I have created a plastic component. First i done slope for draft analysis. Then after sometime used draft analysis.
Now problem is hiw to delete shape analysis from face rendering. As both overlap and not get. Required visual.
Slipe analysis sticks to body. I want to remove it.
RE: How to remove slope analysis in nx9?
Start the analysis -> shape -> slope command and deselect the faces (shift + click); I suggest holding down Shift and rectangle/lasso selecting the entire model. It may not look like anything has changed on the model, but when you press OK (or Apply) the "analysis coloring" will disappear.
www.nxjournaling.com
Go to slope analysis.
Rehighlight faces.
Deselect faces. SHIFT+SELECT
Suyog Patil
CAD Enginer
NX 7.5. 8, 8.5 9, 10 TC-9
