Wall thinning and flattening of bends in boiler tubes
What rule does ASME BPVC code sec I impose with respect to wall thinning and flattening of bends in boiler tubings?
RE: Wall thinning and flattening of bends in boiler tubes
It requires the post-bend extrados wall thickness to be at or above minimum design wall thickness, as would be required for straight tube lengths.
and ovality as required for tolerances stated in boiler tube material specifications.
