Top Angle or Compression Ring
hi guys
i'm confuse between top angle and compression ring.
Can you tell me guys what is the difference between them
and what is the criteria of choosing between them?
Thanks in Advance
Thanks in Advance
RE: Top Angle or Compression Ring
A compression ring is used on a tank with internal pressure to resist the inward tensile forces developed in the roof. A compression ring may be a rolled angle, identical to the top angle above, or may be of various other configurations. See Appendix F in API-650.
Now its clear up my younger mind.
Thank you for the helpful information.
