Relative position of 2 points on a circle
hi
this question was addressed in thread770-356581: Add or subtract polar degrees in Excel but the resulting formula is only valid for points within 90 degrees of each other
stevenal (Electrical) 21 Jan 14 20:12
'=DEGREES(ASIN(SIN(RADIANS(A1-A2))))'
Excel
recap if point A1 is at position 358 degrees
point A2 is at position 01 degrees
above formula returns -3 (position of A1 relative to A2)
but if point A1 is at position 180 degrees
above formula returns +1 (required return is +179)
can anyone expand on above formula to be valid over complete circle (+- 180)
thanks
ziggyS
RE: Relative position of 2 points on a circle
i have changed formula to
'=DEGREES(ACOS(COS(RADIANS(A1-A2))))'
which returns the correct whole number but i lose the polarity
This should work (it works for your examples):
=DEGREES(ATAN2(COS(RADIANS(A1-A2)),SIN(RADIANS(A1-A2))))
There may be a simpler way, but I doubt it can be done with just sin or just cos.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
thanks IDS absolutely perfect!
