How to break links in nx tc for assembly drw?
We have one assembly drw, this in TC and my customer wants only drw in prt format. I dont how to do that. I tried exporting by 2d exchabge in prt but it moves and dimesions from orignal place.
Also tried by breaking links by supression but the views dont show exact drw which was with unsupressed one.
Please help. Our customers always require nx prt file for drw.
RE: How to break links in nx tc for assembly drw?
It is nx 9, 7.5 and 8
when in you situation I usually do a cgm export
but 2d exchange should work for you. I am not sure why things should move
Hello can anyine help with this... My gdnt all get scatared
Hi suyog21.
First of all, I'm sure that the other users on this forum, like me, don't have the time during working hours to monitor this forums constantly...so no need in asking three times in a row if someone can help you....
2D exhchange should work without problems for you..I am also wondering why it is shifting your dimensions and tollerances..
Can you please describe in detail how you performed the 2D exhange?
Maybe try the new Autocad dxf/dwg if you are using NX8.5 or NX9...
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Fil-export- 2D exhange -
Export from - displayed part
Data to export - drawing
Convert gdnt as group
Ok
I have checked on siemens website.. That gdnt does nit support un 2d exchange.
Also tell if supress components. View get affected.as not showing geometry.
