SCADA Monitored Interlocking System
Hi all, does anybody know if there is a scada monitored interlocking system available on the market that can replace the mechanical kirk key interlock?
Thanks!
RE: SCADA Monitored Interlocking System
I have seen micro switches that were attached as part of a Kirk Key system - I believe it was installed so that when the bolt was extended it closed the switch and prevented electrical operation of a cap bank. A quick check of the Kirk Website shows 2 different types of Kirk Key Switches.
http://pdf.kirkkey.com/pdfs/SD%20Series%20Type%20F...
