wiring equipment
wiring equipment
I have a lathe and a drill press I need to wire up. They are mounted to a concrete floor. In order to get the conduit to the equipment I will need to either cut a path in the concrete or use a flexible cord, plug, and receptacle. I cannot find where the cord option is legal according to code. I would appreciate any clarification that anyone can give me. Thank you.
RE: wiring equipment
If the machine is quasi-moveable then at the bottom of the vertical conduit you put a receptacle and use a standard cord with a plug to connect to the receptacle.
Keith Cress
