Direct Analysis Method K=1 verus Euler Buckling Strength Equations-Consistent logic?
I understand that Euler buckling load = the load at which a purely axially loaded column becomes unstable, meaning that any lateral load applied to the column would result in huge flexure and flexure deflection. Euler buckling equations use the “effective length” to define the buckling length of a column, where the k factor comes into play for effective length. And the Euler buckling equation is the basis for the non-short column strength equation in AISC. This makes sense.
I also understand that in Direct Analysis Method, that by using factored loads, notional loads, reduced stiffness, and capturing second order effects, that you are directly modelling and understanding forces and moments that will develop in the columns. So, any column buckling which may want to happen will show up in the form of sidesway and bending in the columns in the analysis. This makes sense too.
What I don’t understand is how the two items above interact. DAM directly defines the forces and moments that develop in the columns which is very logical. But then we use the same column strength equations (basically just Euler buckling equation), but we just hold K=1. This doesn’t “click” for me, and it just feels like an approximation that is just “close enough”. Is the real story that we don't care about Euler buckling anymore because we have already modelled the real buckling that could happen and confirmed it can't happen? So then the column strength equation becomes a little more aggressive but not as aggressive as simply using P/A or something similar?
I appreciate any insight or advice you can give.
RE: Direct Analysis Method K=1 verus Euler Buckling Strength Equations-Consistent logic?
The real world effects (eccentricity, ... ovaloid chickens with feathers in an atmosphere ...) that DAM analyzes aren't solvable the same way, and don't arrive at a similar closed form solution.
1) DA method isn't just trying to capture the type of ELASTCIC buckling that Euler buckling calculations predict. Rather it is trying to also predict the inelastic buckling that really occurs in steel structures. This is an important difference.
2) There are multiple methods of buckling. Flexural buckling in the strong and weak axis, Flexural torsional buckling, torsional buckling et cetera.
More to follow later.
Exactly this. Future versions of the direct analysis method won't have even K-values because they won't involve Euler buckling.
If we model all of the factors leading to instability including second order and non-linear effects, there's no need to bother with Euler buckling. And we have the technology to do this.
At present, our codified analysis methods account for many instability sources but not all of them. The K=1 Euler checks attempt to fill that gap. The way in which they do so is generally conservative and, really, not all that consistent with our more modern methods. Apples and oranges.
Anyways, the direct analysis to overcome this, forces you to analyze the non sway + the sway case with a reduced stiffness in the members adding lateral stiffness, this is somewhat empirical and that's why you can use K=1. Now if you're using some other method [elastic or the magnified moments, you need to calculate the K's for the sway case]. I think the problem of these methods it's the actual reach of what we know or what we pretend to know. I think researchers rather than putting a big safety factor and making an easier equation to calculate the strength of members tend to use what we currently know about analysis and material behaviour and make everything thrice as complicated for a .004$ gain in accuracy.
In a way, whatever analysis may tell you which if you go to the field and compare your models you tend to realize all the crap you take for granted or oversimplify and in no way you will believe the fancy analysis especially when non-linearities are involved.
4) Then there is overall buckling of the frame / system? That isn't really addressed by simple KL/r assumptions for individual members.
5) If the Direct Analysis Method truly accounted for all forms of stability, then we could take KL = 0 and just use the yield strength of the member as the capacity. And, that option will likely be coming for some future version of the code. However, that is much more dangerous. You're expecting a lot more sophistication out of your analysis (and the engineer who built the analysis model) if you use KL = 0.
So, we have this hybrid method (DA Method) that accounts for stability effects mostly through the direct analysis of the structure. But, the method is simple enough to use that most engineers (and analysis programs) can use it properly with confidence that their results are reasonably conservative.
It will be interesting to see what future AISC releases say about column strength checks against Direct Analysis Method results.
