complex spline simplification in catia
Hi to all. I have one more question of how can i keep only the outside of the spline attached below. I have tried things like clean contour and power fit but with no luck. I cannot use things like disassemble and delete each one of them manually cause this cleaning process will be adjusted in a script which will be used in a set of 100 different splines with the same problems. So, any help will be more than appreciated. Thanks.
RE: complex spline simplification in catia
how many spline in your file?
do you have 2 contours or do you have 100+ lines going from pt to pt?
Eric N.
I have several splines going from point to point, so lets say that I have 100 splines. One of the points is connected with the previous and the next points with a spline, but the same point also is connected with a third point which is lets say inside the contour that I want to keep (which is the outside). At the end I have to create a join with all these spline so as to have one closed contour.
