Belt Length Calculation
Could someone please explain the relation between "Pulley diameter over balls" and Belt ?
How can a calculate the Outside Belt length ?
01. I have a Gate Micro V Belt, belt thickness is aprox 5.15 mm
02. Pulley Groove angle is 37 deg and Ball dia is 2.5
03. DOB is 62
...I know we need another pulley for belt
But, my question is, how to correlate radius of Pulley DOB with Belt
Is the center of Pulley ball coincident with Belt ball ? (2.5 mm ball in belt groove)
What is the relation then to Backside of belt ?
03. DOB is 62
RE: Belt Length Calculation
See, for example, this calculator from a manufacturer:
http://www.durabelt.com/beltlengthcalculator.php
What is the relation between Radius of center gauge ball in pulley groove and center of gauge ball in belt groove ? (a section cut thru belt wrapped around pulley)
Are these radius equal ?
The center ball tie together the pulley and belt ?
how to correlate, how to "jump" from pulley to belt ?
I do not have a section of pulley-belt togheher
a pulley is usually defined by DOB (diameter over ball), ex : DOB=100, ribs angle 37, pitch ribs=3.56
Belt V is : angle 40, pitch=3.56, thick 5 mm
so I need to correlate effective/outside in belt with pulley
what effective in belt correspond in pulley ?
