NX9 Face Curvature
NX9 Face Curvature
I am getting an error "NX License Error: License server system does not support this feature this feature. {-18}",
When I try either Analysis > Shape > Face Curvature, or Analysis > Shape > Facet Body Curvature.
Analysis > Shape > Draft Analysis works fine.
Analysis > Shape > Concave Faces works fine.
Is this a "We don't have the correct license/package problem" or something else???
I had this same error with other selections when I was at 9.0.0.__ , I am now at 9.0.2.5.
We use a License server with bundles "NX Mach 2 Prod Design" and "NX Adv Designer".
I have tried with both bundles.
Rick
Rick
RE: NX9 Face Curvature
Neither of the two bundles you have has either of those features in them.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
If you have access to the directory in where the NX license software resides ( Or if you speak to your sysadmin) there is a logfile from the license server, reading this logfile (Notepad) it will report whats wrong on the last line when you get this message in NX. ( This is how I and presumably Anthony checks what license a feature requires.)
Tomas
