Export BOM with model in UGNX 7.5
Is there any way to export a UGNX 7.5 model file to STL or IGES with the item callouts as found in the BOM? Any suggestions would help.
RE: Export BOM with model in UGNX 7.5
Iges should support both partslist and balloons since Iges supports drawings.
STL was originally meant to be used for Stereo Lithography machines. ( i.e "3D printers" ) I would be surprised if there was support for Partslists.
Tomas
