not shown lines in drafting
sometimes on drafting side some lines are lost. Does someone know how to bring them? In the file I attached you see a small assembly and the lines of the guide rails are disappeared(even though you can see end part of it).
(NX7.5-NX.9.0)
(NX7.5-NX.9.0)
RE: not shown lines in drafting
but it also could be due to interfering solid bodies
This is funny but those lines became visible when I changed un the "Representation" from "Exact" to "Smart Lightweight". I would think that exact option should include more details than lightweight :)
If that doesn't work, that I am aware, the only other alternative is manually drawing in the intersection lines in that particular view.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
In View Style go to the "hidden lines" tab, and under "Interfering Solids" check "yes, Without Interfering Solids" or "yes, With Interfering Solids"
Very often this will solve the problem of missing lines.
Using NX 8.0 and Teamcenter 8 on Windows 7 (64)
