Pump performance at different frequency
hi all,
i want to utilize an existing 60 hz centrifugal pump in the 50 hz electrical system in the plant. i need to evaluate the discharge pressure of this. pump performance curve available from the vendor is only available at 60 hz - 3560 RPM. I have tried to contact the vendor but somehow they did not respond.
is there any equation to relate frequency to head/discharge pressure of centrifugal pump ? i want to evaluate the discharge pressure of a 60 hz 3560 RPM centrifugal pump if it is operated at 50 hz and 290 gpm
thanks in advance
thanks in advance
RE: Pump performance at different frequency
These are the basic "laws of affinity" for centrifugal pumps. Easily Googleable.
As pointed out by DubMac - first 5 minute of basic 101 pump lessons.
If the wheel diameter is constant, change in pump wheel velocity can simplify the affinity laws to
dp1 / dp2 = (n1 / n2)2
n = wheel velocity - revolution per minute - (rpm)
dp = head or pressure
but...how do i calculate the rpm ? if i change the frequency ?
(50/60) x 3560 = 2967 RPM
so, if the discharge pressure of the pump at 60 hz is 193 psig. it means the discharge pressure at 50hz is :
193/dp2 = (3560/2967)^2
dp2 = 134 psig
am i wrong ?
and how about the NPSHr ? does it remain constant ?
at 60 hz, the NPSHr is 12.5 ft
Your 50Hz pressure of 134 psi based on above is OK.
NPSHr, again - unless accuracy is needed NPSH can be assumed to remain fairly constant, but again, if accuracy is needed ask the pump manufacturer for 50Hz NPSHr curve.
