DXF to Gerber conversion
I wish to use a small pcb router that normally takes gerber files from PCB design software to do some simple 2D work from DXF data. Just need tool paths and drill centres.
Any body know where I could get DXF/Gerber conversion done for free?
thanks
thanks
RE: DXF to Gerber conversion
Searching on "Gerber translator free" turns up something useful as the very first hit.
Dan - Owner
http://www.Hi-TecDesigns.com
Plenty of free PCB design programs out there too that obviously export gerber..
I like Diptrace..
I am using Solid Edge to generate dxf. There are SE utilities available but at a cost. I only want to experament.
Dan - Owner
My cad system outputs DXF. Router takes Gerber.
I can also export .igs, .pdf, .dgn .dwg in 2D format
Dan - Owner
Z
For sure it' doable with Altium, but it's not free, I don't know for Eagle, or other free ecad
Dan - Owner
