Hide components in Drafting view
How would I hide a component in a view in drafting mode?
I need to not show a component that is part of an assembly.
I am using NX 7.5
I am using NX 7.5
RE: Hide components in Drafting view
www.nxjournaling.com
Your solution does work. But there is another issue that is related.
The view that I need to hide a component is a half scale view of original full size
front view of assembly. When I hide the selected component in the half scale
view it also hides the same component in the full size view.
Any way around this?
Try using the "show component in view" on the view where you want to see the component.
Yes, you were right. Somehow I had 2 views selected. Everything works perfectly now.
Thank you so much!
