Problem with oscillation motor in basic motion module
Hi
I set up an oscillating rotary motor in one of my models to oscillate through 90 degrees but it only rotates by 1 degree maybe 2 at a push.
Anybody else had this issue?
I had a look at a few examples on line & cant see where or if I have made an input error.
RE: Problem with oscillation motor in basic motion module
The following isn't the correct way to diagnose the problem, but...
What I like to do (especially when I'm not the original designer of the part/assembly) - what I like to do is 'blow away all the mates.' Go to the 'mates' - then just delete them all - or suppress them one by one. In that way it's easy to troubleshoot your part a little better.
SW Professional 2014 SP 5.0
SW Electrical 2D/3D SP 5.0
64 bit
Intel Xeon X(R) CPU 1603 0 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
Thanks I just did that and ended up finding the offending mate buried away in one of the sub assemblies.
