NX9 Library: no preview or select dimension window
NX9 Library: no preview or select dimension window.
I have the complete NX Library installed but when I want to add a part I don't see a preview.
I can open the source folder and drag the part in. But then I don't get de window to select the preferred dimensions of the part.
Is there something wrong with my NX installation?
RE: NX9 Library: no preview or select dimension window
Make sure you have the "member select" window expanded.
www.nxjournaling.com
that was the problem. I feel so stupid for not noticing that.
I have another problem. When I set my assembly load options to "From search folder" it turns back to "From folder" after I restart NX.
How can I make this permanent?
Once you get the load options set to how you want them, hit the "save as default" button.
