Selection Scope in NX10 not like it was in NX9
Any one else notice they changed the way you pick your stuff on the screen, from NX9 to NX10, I think it sucks in NX10 and is cumbersome to use. Why can't they just leave the way it was, I know there is a maintenance release out, and that still didn't fix the problem.
RE: Selection Scope in NX10 not like it was in NX9
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
While I have no excuse, this is obviously not working correctly and is a regression from previous versions of NX, to suggest however that "it still isn't fixed" in the latest MR (Maintenance Release) is a bit harsh considering that we've only had time for one MR so far. NX 10.0 wasn't released until late in December and I suspect that not all that many people have installed it yet and development of the first MR closed several weeks ago so it's not all that surprising that it wasn't found and fixed sooner. Granted, that's not a good excuse and we perhaps should have found it during beta and our internal testing, but that's water over the bridge. When did you report this to GTAC and have they given you any indication that it has been fixed or will be shortly? If they have, did they say whether it will be fixed in an MP (Maintenance Patch) or will it have to wait for the next MR?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
only the multi select by rectangle/lasso is wrong. And yes this should be fixed, but it will not be priority 1.
If you find something which crashes, gets corrupted, or doesn't have workaround, then it is prio 1.
- It might take a little time before this is corrected.
Tomas
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
