embedment for pile cap
Using helical piles, the embedment in a pile cap is 8 inches. The Pilecap total depth is 2 feet. What is you guys opinion/thoughts on the amount of helical pile embedment on this?
RE: embedment for pile cap
Playswow,
I little advice that will take you a long ways after your school career ends. If you bring a question to the table, bring your best answer as a starting point. This does a few things:
1. it tells everyone that you are not trying to get people to do your homework
2. it might just solve your problem
3. it shows your piers and future bosses that you are approaching your job with zeal. This will take you a long ways.
Using the CRSI tables I would increase the total pile cap depth by at least 2" as CRSI uses a 6" embedment of the pile if I remember correctly. I would also use the CRSI pile cap depth as a starter.
Mike McCann, PE, SE (WA)
bigmig
What? Why would you assume that from this question? I'm out of school but yes, I am a EIT with about a year of experience.
Mike McCann
Thanks man I will locate and use that resource.
In my area, helical piles will be installed long and then be cut down to the appropriate elevation before installing the cap plates. As such, vertical control isn't too bad. I'd say that you could embed the pile as little as 2" and be reasonably sure that, at the end of the day, there won't be air space between the underside of your pile cap and the top of the pile. It very much depends on the detail that you're using however.
Thanks KootK,
Pile Cap Dim = 200 sq ft
Some vessels are approximately 250 to 500 kips, so you can see why I asked ha
