thread inspection
thread inspection
thread inspection
MIL-S-8879 says inspection per FED-STD-H28/20. H28/20 has 21, 22 and 23 systems.
who determines the system? if the customer drawing says nothing about inspection, which system to use?
is ring/plug gauge suffice or have to use Johnson type gauges?
thanks.
RE: thread inspection
If nothing is specified, use what is easiest. Personally, I would choose ring/plug go- and no-go gaging.
MIL-S-8879 section 4.4.3 basically states any inspection method described in FED-STD-H28/20 or ANSI/ASME B1.3M is acceptable provided the inspection method assures conformance to the requirements listed in MIL-S-8879. The best choice of inspection technique depends on the particular application. Johnson gaging fixtures are a bit pricey, but they provide actual dimensional/tolerance data. If you are conducting a first article inspection you may be required to record actual measurements, which Go/No-Go gauges don't allow.
Go/No-Go ring and plug gages are not as expensive, but they only provide a pass/fail result. If the threads are being produced by different outside vendors the ring and plug gages are easy to transport and are far less likely to be damaged. Ring and plug gages also make it easy to perform a quick inspection of the thread while the part is still set up on the machine.
I've attached the relevant section of MIL-S-8879 for your reference.
