NX8 Associative Measurement to set expression value
I am writing a journal to create an airfoil geometry which set by expressions. The journal will be used 1 time to set the geometries and expressions, after that the geometry changes will be made only by the expressions.
My question is, is there a way to define an associative vector expression to an associative datum axis created at an associative percentage of a spline.
For example i have a camberline (studiospline), at 50% of that curve i created a datumaxis normal to the curve. I want to create an associative vector expression that defines that datumaxis. When the inputs are changed, the camberspline will change thus, the datumaxis will change. I want the vector expression also change.
I will explain a method i tried. I created an associative angle measurement between the datum axis and the X-axis, so i have an angle. Then i created a Vector expression "Vector(cos(angle),sin(angle),0)". But the measurement name is automatic (ie. p2) and i can't define this name in journal. I want the journal to create an expression "Vector(cos(p2),sin(p2),0)" if the measurement name is defined as p2 automatically. I setname to measurement, i tried the journalidentifier and the tag but i can't manage to do what i want.
Any help will be appreciated.
Codes are given below.
Function that creates datumaxis
CODE --> C#
public static DatumAxis CreateDatumAxis(Part thePart, NXOpen.Features.StudioSpline spline, double spline_percent, string name)
            NXOpen.Features.Feature nullFeatures_Feature = null;
            NXOpen.Features.StudioSpline studioSpline1 = spline;
            Spline spline1 = (Spline)studioSpline1.FindObject("CURVE 1");
            NXOpen.Features.DatumAxisBuilder datumAxisBuilder1;
            datumAxisBuilder1 = thePart.Features.CreateDatumAxisBuilder(nullFeatures_Feature);
            datumAxisBuilder1.Type = NXOpen.Features.DatumAxisBuilder.Types.OnCurveVector;
            datumAxisBuilder1.ArcLength.IsPercentUsed = true;
            datumAxisBuilder1.CurveOrientation = NXOpen.Features.DatumAxisBuilder.CurveOrientations.Normal;
            datumAxisBuilder1.IsAssociative = true;
            datumAxisBuilder1.Curve.Value = spline1;
            datumAxisBuilder1.ArcLength.Path.Value = spline1;
            datumAxisBuilder1.ArcLength.Update(NXOpen.GeometricUtilities.OnPathDimensionBuilder.UpdateReason.Path);
            datumAxisBuilder1.ArcLength.Expression.Value = spline_percent;
            datumAxisBuilder1.IsAxisReversed = true;
            NXObject nXObject1;
            nXObject1 = datumAxisBuilder1.Commit();
            nXObject1.SetName(name);
            datumAxisBuilder1.Destroy();
            NXOpen.Features.DatumAxisFeature a = (NXOpen.Features.DatumAxisFeature)nXObject1;
            return a.DatumAxis;
Function that creates the measurement
CODE --> C#
public static Measure CreateNormalVectorAngleMeasurement(Part thePart, DatumAxis axis1, DatumAxis axis2, string name)
            NXObject nullNXObject = null;
            MeasureAngleBuilder measureAngleBuilder1;
            measureAngleBuilder1 = thePart.MeasureManager.CreateMeasureAngleBuilder(nullNXObject);
            measureAngleBuilder1.Object1.Value = axis1;
            measureAngleBuilder1.Object2.Value = axis2;
            Unit nullUnit = null;
            MeasureAngle measureAngle1;
            measureAngle1 = thePart.MeasureManager.NewAngle(nullUnit, axis1, NXOpen.MeasureManager.EndpointType.StartPoint, axis2, NXOpen.MeasureManager.EndpointType.StartPoint, true, false);
            Measure measure1;
            measure1 = measureAngle1.CreateFeature();
            measureAngle1.Dispose();
            measure1.SetName(name);
            measureAngleBuilder1.Destroy();
            return measure1;
Main code
CODE --> C#
public static void Main(string[] args)
            Session theSession = Session.GetSession();
            Part workPart = theSession.Parts.Work;
            Part displayPart = theSession.Parts.Display;
            CamberClass Camber = new CamberClass(workPart, theSession);
            #region Camber Inputs and Expression
            Camber.B1m = 19.0;
            Camber.B2m = -65;
            Camber.Cax = 14.115;
            Camber.Stagger = -38.45;
            Camber.grc = 1;
            Camber.degree = 3;
            Functions.CreateExpression(workPart, "B1m", Camber.B1m.ToString(CultureInfo.InvariantCulture), "Number");
            Functions.CreateExpression(workPart, "B2m", Camber.B2m.ToString(CultureInfo.InvariantCulture), "Number");
            Functions.CreateExpression(workPart, "Cax", Camber.Cax.ToString(CultureInfo.InvariantCulture), "Number");
            Functions.CreateExpression(workPart, "Stagger", Camber.Stagger.ToString(CultureInfo.InvariantCulture), "Number");
            Functions.CreateExpression(workPart, "Camber_grc", Camber.grc.ToString(CultureInfo.InvariantCulture), "Number");
            Functions.CreateExpression(workPart, "Camberdegree", Camber.degree.ToString(CultureInfo.InvariantCulture), "Number");
            //degree>3 input Cys
            if (Camber.degree > 3)
                Camber.Cy.Add(3);  //y coordinate of control points except P0,P1,Pn-1 [P2=Cy(0)...Pn-2=Cy(degree-4)]
                Camber.Cy.Add(-5); //Degree-4 //e kadar gir, girilmezse 0 alır
                for (int i = 2; i <= Camber.degree - 2; i++)
                    Functions.CreateExpression(workPart, "Camber_Cy" + i.ToString(), Camber.Cy[i - 2].ToString(CultureInfo.InvariantCulture), "Number");
            #endregion
            Point3d StartPoint = new Point3d(0, 0, 0);
            NXOpen.Features.DatumCsys ABSCSYS;
            ABSCSYS = Functions.CreateAbsoluteCoordinateSystem(workPart, "Absolute Coordinate System");
            Camber.CamberControlPointsExpressions(StartPoint, "Camber");
            DatumAxis x1;
            x1 = Functions.CreateDatumAxis(workPart, Camber.CamberSpline, 50, "datum1");
            DatumAxis x2;
            x2 = (DatumAxis)workPart.Datums.FindObject(ABSCSYS.JournalIdentifier.ToString() + " X axis");
            Measure a;
            a = Functions.CreateNormalVectorAngleMeasurement(workPart, x1, x2, "a1");
The section below creates the measurement. Now i want the journal to create an expression of a vector "Vector(cos(p2),sin(p2),0)" if the measurement name in expression tab is p2.
CODE --> C#
DatumAxis x1;
            DatumAxis x2;
            Measure a;
RE: NX8 Associative Measurement to set expression value
I figured out the solution.
CODE --> C#
DatumAxis x1;
DatumAxis x2;
Measure a;
After the "measurement a1" is created by the code above. NXObjectManager.Get gets the measurement expression. Then .Name method gives the automatically assigned measurement name (i.e. "p2").
CODE --> C#
Expression n1 = (Expression)NXObjectManager.Get(a.GetExpressions()[0].Tag);
Functions.CreateExpression(thePart, "V1", "Vector(cos(" + n1.Name + "),sin(" + n1.Name + "),0)", "Vector");
CreateExpression function is given below
CODE --> C#
public static void CreateExpression(Part thePart, string expName, string expValue, string expType)
            thePart.Expressions.CreateSystemExpression(expType, expName + "=" + expValue.ToString(CultureInfo.InvariantCulture));
