How long to fill a specific volume to a specific pressure?
Morning!
I've been asked to confirm how long it would take to fill a 445,000 litre volume to a pressure of 1.2kPa using a air source that provides 130 litres a second of air at a pressure of 620kPa.
Firstly, this seems like a very low pressure to set the volume to (1.2kPa). But' I've calculated it would take almost 7 seconds to fill this volume to 1.2kPa using this air supply.
Would that sound about right do we think??
Cheers
Craig
Cheers
Craig
RE: How long to fill a specific volume to a specific pressure?
If those assumptions are correct, then the mass difference between open to atmosphere and 1.2 kPag is 6.44 kg. Your source puts out 0.158 kg/s. That works out to about 41 seconds.
On the other hand if your test pressure is 1.2 kPaa, then this would be an evacuation problem, and you are evacuating 535 kg. Assuming that your compressor capacity is the same at atmospheric pressure and at 1.2 kPaa (an absolutely invalid assumption) then it would take about an hour. With real life equipment figure 12 hours.
Working this problem in volume units is an excellent way to end up outrageously confused.
Do you see what sloppy specifications get you?
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
David Simpson, PE
Therefore one could convert the 130L/s STP rate into an instantaneous delivery rate into the bottle, then calculate the bottle's instantaneous pressure.
Do that in small time steps, using average delivery pressure of the time step, and arrive at an average injection rate across each timesetp, finally reaching a solution of 17.8 seconds.
(ignoring compressibility and assuming isothermal process and an ideal gas)
That is exactly what you have to do when you get closer to the same pressure on the two systems, but going from over 600 kPag to 1.2 kPag is really a constant flow rate exercise. It is a lot easier to work in mass units. Working in standard volumes is mathematically, correct but an engineer who uses the term "kPa" instead of "kPaa" or "kPag" is going to trip over his feet a couple of times doing that calc in STP (notice that he thinks that it should take 7 seconds to fill).
The convention for air compressors is not STP but actual conditions at the suction plenum at the location of the manufacturer's test. That causes no end of confusion, but it is the convention. I'm so glad that compressors for industrial gases abandoned that stupidity in favor of STP.
David Simpson, PE
Your op states "delivers 130 l/sec at 6.2 barg"
If this is correct then your calculation isn't far off IMO.
However if your compressor size is actually like zdas04 states then his calculation makes sense.
Which is it?
If the mgfr's test bench is in Denver he should convert to Sea Level to sell more compressors.
Are you actually converting 130 L/s at discharge conditions to a mass flow rate (or a volume flow rate at standard conditions)? What temperature are you using? There never has been a compressor whose capacity was rated at max discharge pressure (and the associated discharge temperature) at ACM. If he was filling the system from a tank that is about 10 times the size of his system, then his calculation might be OK, but compressor discharge pressure is absolutely controlled by the pressure downstream of the discharge check valve. If that pressure is 1.19 kPag, then the compressor discharge will be something like 1.21 kPag. The mass flow rate at that point is going to be somewhere pretty close to 130 (std)L/s and the fill time is right around 40 seconds.
David Simpson, PE
Jeez, I was just trying to point out that the point at which you took the 130litres makes a difference.
If you read the OP carefully, he or she doesn't state they have a compressor, only a "source" of compressed air. You are the one who introduced the compressor into this. Now that "source" could be an air line, a plant air supply or indeed maybe a compressor - who knows, but "source" is what it says. I agree we don't know the temperature, but I think we can assume 15 to 20C for the purposes of the calculation.
Hence if we assume it is a piped supply from some remote air receiver, then if there was a regulator regulating down to 102.2 KPaa, and the supply is being measured in litres at 6.2 barg then it might work. Of course I doubt this regulator exists or whether issues such as temperature drop, sonic velocity, choked flow etc have been considered as filling 455 cubic metres admittedly to a fairly low overpressure in less than 7 seconds just sounds wrong / impractical. I suspect in practice a much slower rate would be required, if indeed the 130l/sec is being measured at 6.2 barg.
I agree it would be much better to use scm and absolute pressures in all sections then it makes life much easier...
David Simpson, PE
Thank you for your input with this issue.
I agree that the lack of confirmation over the units would create issues and errors in every engineering problem in all walks of life - the information I included on my origional message was the information that I received from our site team. I have asked if it is kPaa or kPag, and I have not received a response. Sometimes, you just have to find a way to work with what you're given and maybe present a few cases for different scenarios.
But I was asking in the forum to try and get a bit of confidence in the method I was following.
LittleInch,
Yes, the air is delivered at a rate of 130 l/sec at 6.2 barg (I am going to assume that is "g"). It is supplied from a plant air supply, and those are the conditions of the air supply. I agree 7 seconds sounds wrong, and that is why I thought I'd bring it to the forum for a discussion.
.....Every day is a school day, and today, my lesson is, don't ask questions unless you have all your facts straight.
Have a good day everyone.
The 7 seconds is one of those things that looks theoretically possible, but in practice not so.
The 130 litres/second converts to about 850 to 900 litres/sec at the tank pressure. It would be a good check to see what that equates to in velocity terms of the pipe feeding the tank. Anything more than sonic velocity will tend to cap the potential pressurisation speed....
If that's gauge pressure than the 620kPa is also probably gauge- and given the time period is so small- it doesn't make much difference (practically speaking) if it's gauge or absolute.
Is the smoke going to be introduced into the air supply or will a smoke bomb be put in the tank followed by pressurising the tank?
In the scheme of things- if the smoke is already inside the tank it'll take <1 minute (as per posters above) regardless of whether the volume quoted is inlet or outlet conditions of a compressor/plant air system.
I've spent longer than that writing this up- don't sweat it. A better use of your time would be to ask how are they going to limit the pressure the tank can achieve during the test in case someone leaves the air supply on longer than they should.
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
LittleInch - thanks again for that confirmation.
I’d like to add just a note. It has not been mentioned anywhere but I assume the filling of the reservoir will take place through a nozzle. According to the numbers presented in the OP the flow will be choked, so the choked mass flow rate can be calculated with the following equation
M dot = Cd*A*SQRT(k*rho1*P1*0.528)
Being
Mdot = mass flow rate [kg/s]
Cd = coefficient of discharge of the nozzle
A = discharge cross section area [m2]
k = ratio of specific heat (1.4 for air)
rho1 = density at upstream conditions [kg/m3]
P1 = upstream absolute pressure [Pa]
This value will allow you to calculate the min filling time, knowing the upstream conditions and nozzle geometry.
Thank you all.
Are you sure they haven't misread a capacity somewhere 130 l/hr maybe?
As you may have gathered - this area of engineering isnt a strong point of mine, hence me approaching the group. I dont even know the diameter of the delivery hose so cant even determine if its is a realistic value.
.....Give me a pipework design problem any day.....
It could even be that the air supply CAN supply UP TO 130 l/sec, but whether it can or not is the question to be asked. It implies a pretty large air supply line and air system which may be correct, but if they think it is going to take hours then there seems to be a rather big disconnect here - perhaps they are looking a small air compressor and thinking this is going to take hours..... Who knows - we don't.
David Simpson, PE
Smoke test, right? So the tank starts out dirty, then you are adding clean gas to dilute the smoke if I understand your statement?
So how are you going to assume the original and final "smoke" is well-distributed? That is, if you air adding the diluting ((clean ?) compressed gas into the 15715 ft3 (443 cubic meter) tank from just one nozzle very slowly, are you sure the final gas + diluting clean air is going to be mixed thoroughly? If there's a difference in density, the mixing will be even less.
