NX9.0 split body problem
I have a problem with the splitting body operation in NX 9.0.
I try to split a simple body with two faces, but fails.
Same result happens using Catia.
Can anyone understand why this happens?
RE: NX9.0 split body problem
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
So if this is what you're really looking for, you're either going to need to approach this problem from another direction or else, for a more general solution, first 'Split' the original body into two bodies, perform the individual 'Split Body' operations and then 'Unite' the original model back together again, as I've done in the example attached below.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
John's explanation about how it works internally makes sense.
I understand using one sheet body to split the body will result in non-manifold model which is not supported in NX CAD.
However, I still think it should be possible to work in the model i offered using the two sheet bodies.
Hope this can be improved in future version.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I think it should be able to be that smart.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
