position between any drawingtext
hi freind,
if it's possible can you help me?
I was creat one drawing when i put lot of drawingtext. I give a position in X for all drawingtext, but in Y i went put the same space between a drawing text.
Set drawingDocument1 = CATIA.ActiveDocument
Set drawingSheets1 = drawingDocument1.Sheets
Set drawingSheet1 = drawingSheets1.Item("plan...")
Set drawingViews1 = drawingSheet1.Views
Set layout2DView1 = drawingViews1.Item("Composant 2D.2")
Set drawingPictures1 = layout2DView1.Pictures
Set parameters1 = drawingDocument1.Parameters
Set strParam1 = parameters1.Item("Chaîne.31")
Set drawingPicture1 = drawingPictures1.Item("Image.7")
Set drawingPicture2 = drawingPictures1.Item("Image.5")
set octextinit=layout2DView1.Texts
set octextinit1=layout2DView1.Texts
for k=1 to octextinit.count
for k=2 to octextinit1.count +1
Set oTextinit = octextinit1.item(k)
Set oTextinit = octextinit.item(k)
oTextinit.X = 945
oTextinit.Y = oTextinit.Y +5
next
Set ocText2 = layout2DView1.Texts
For j = 1 To ocText2.Count
Set oText2 = ocText2.item(j)
If oText2.Text = "THREADS AND AREA NOT PAINTED" Then
oText2.X=966
drawingPicture2.X = oText2.X-20
drawingPicture2.Y = oText2.Y-12
End If
next
oTextinit.X = 945
next
oText2.X=966
End If
next
RE: position between any drawingtext
Your macro is very specific, I see in your code a mix of French and English words and this can be a problem. Can you upload a sample to see how your macro can be done "universal"?
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
