Tapered Octagon/ Dodecagon A-frame Column Design
Within the ASCE 48 there are provisions to check the local buckling against an allowable compressive stress based on w/t. There is also a section based on truss members, that per the definition is a member that is designed to only withstand axial forces, that takes into account the unbraced length of the member. In an A-frame situation I can run into quite high compressive forces with moments. What would be the appropriate way to check the global buckling capacity of the tapered column section? There does not seem to be any provisions for checking the column section as a whole for allowable compression based on unbraced length when moments and shears are present. Any help/ thoughts would be much appreciated
RE: Tapered Octagon/ Dodecagon A-frame Column Design
Many of the members of ASCE 48 will be in Branson, Mo for the SEI conference later this year, if you want to talk to the real experts in person.
You can also look at ASCE 113, which we are currently revising. It covers dead end A-Frames but refers the design of the members back to ASCE 48.
_____________________________________
I have been called "A storehouse of worthless information" many times.
Thanks for the head up on the SEI conference, might have to make that trip and try talking to some of them.
I don't know if the PLS boys have a demo version of PLS-POLE but it is widely used. They are considering putting in a deflection load case check for substation structures but it is not at the top of their list.
http://www.etsconference.org/
