Meaning "Circuit Pressure Drop"
I am a graduate process engineer. I am now really confused about the term "Circuit Pressure Drop". I am not sure whether it means the pressure drop between one equipment and its downstream equipment in an oil and gas plant or the total pressure drop of the whole plant.
Could anyone please explain me regarding with my question?
Thanks a lot in advance.
With Regards,
Soe Bo Bo Latt
Graduate Process Engineer
With Regards,
Soe Bo Bo Latt
RE: Meaning "Circuit Pressure Drop"
Of course in your company or plant this could be used for something else incorrectly, but has become the standard way of talking about it.
Choose your moment (and the person), but if you're not clear about any term or expression, ask - it's how all of us learned when we first started out. It's always best to do some work yourself first and start off with "Can you help me to understand "xxx", I think/thought it means this, but I'm not sure..."
If you design a chilled water pipe system, then you have had to calculate the total circuit pressure drop in order to select the pump head.
