Device that can generate a digital signal when sensing a 230V AC supply?
What kind of device can I use to generate a digital signal (maximum 24V) when it is fed with a 230V AC supply? Device is to be mounted on a power distribution panel.
RE: Device that can generate a digital signal when sensing a 230V AC supply?
The simplest device would be a wall-wart. Or a small PSU with 24 V output.
If tolerances are important. Or fast reaction. Or frequency or phase symmetry or phase sequence - then look for AC voltage relay, frequency relay or anything close to what you are looking for.
Gunnar Englund
www.gke.org
What do you mean by "a digital signal"? Technically, a relay contact that opens or closes is a digital signal; 1 or 0, but so is a stream of 1s and 0s in data pulses corresponding to some value that need to be generated at one end and interpreted at the other end.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
A relay with a 230 vac coil.
