API Tank adequacy check for next 20 years
Hi All,
I have received a request from client to asses existing tank and prepared adequacy check report for next 20 years of service.
http://www.eng-tips.com/
I understand API653 and API579 codes to be followed for the assessment.
Anybody have experience in these codes? When to use API653 and when to use API579 ?
Kindly through some light on differences between these two API codes ?
Best regards
Best regards
RE: API Tank adequacy check for next 20 years
The American Petroleum Institute initiated an Above Ground Storage Tank Inspector Certification Program with the issuance of Supplement 1 to API 653, Tank Inspection, Repair, Alteration, and Reconstruction. The program was developed with the participation storage tank owner/users, and establishes a uniform national program that will assist state and local governments in above ground storage tank regulations.
The API 579 Fitness-for-Service Standard assessments are quantitative engineering evaluations that are performed to demonstrate the structural integrity of an in-service component containing a flaw or damage.
Whether or not API 579 is applicable depends on what type of "tank" that you are inspecting.
http://www.tappi.org/downloads/conference-papers/2...
Thank you very much for the reply.
Best Regards
MVK
