Convert .ipt to .x_t
RE: Convert .ipt to .x_t
Those are native Autodesk Inventor files.
Why did you think that anyone here would be able to convert those files for you? If you've got an Inventor license why aren't you exporting them as .dxf or .dwg formatted files yourself? And if they are not your files, why are you not asking whomever supplied you with them to provide you with .dxf or .dwg versions instead, of for that matter, in IGES or STEP?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I do not have an Inventor license, and these files were gathered from GrabCad. Unfortunately this is the only acceptable file I could find and it is in a format I cant work with.
You would think so, but not one person has been able to help. Or maybe just not willing to help.
If you check the internet it's possible that you may find someone who provides 'conversion' services for situations like this where you have no control over the format of the original files and yet you still need to get them converted into a format that you can deal with. Of course, these commercial services will not be without some cost to you, but it's one solution.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I just goggled ipt to .x_t and got some nice results
