best cast for a small part
I am looking to have someone build a steel cast for an aluminium part i am looking to produce myself. What type of cast would be best suited for this application. ITs a very small part. so i am running into issues finding a company that would even make a cast for me.
thanks
RE: best cast for a small part
If all you require is a few dozen examples of your small aluminum component, you should consider using some rapid prototype process like metal laser sintering.
Good luck to you.
